I need help with dark mode
I just want dark mode. I dont get dark mode in qubes manager. Heres what i tried to do.
  1. sudo qubes-dom0-update qt5ct qt5-qtstyleplugins
  2. export QT_QPA_PLATFORMTHEME=qt5ct
  3. qt5ct
    Then i put it on dark mode
Still no dark mode
I also tried
1 sudo vim /etc/environment
2 i
3 QT_QPA_PLATFORMTHEME=qt2k
4 esc
5 :x
Im not sure WHAT im doing but we all start somewhere right
Hmm, looks like you was using different (maybe wrong) commands…
First is install qt5-qtstyleplugins package in dom0 terminal with:
sudo qubes-dom0-update qt5-qtstyleplugins
in /etc/environment it should be
QT_QPA_PLATFORMTHEME=gtk2
then insert in dom0 terminal
export QT_QPA_PLATFORMTHEME=gtk2
And then your qubes manager probably will went dark…??
…after the next reboot?
Hey that worked, thanks
I have been looking for a way to make Qubes Manager turn to Dark Mode…and this post helped me… Thanks… Highly appreciate it :smiley: :+1:
