Error: Malformed stanza 1 in source list /etc/apt/sources.list.d/brave-browser-release.sources (type)
Error: The list of sources could not be read.
I checked it several time to make sure I didn’t make any type-Os and tried it again. Same thing. This was late last night so I called it quits.
To day I went into the same Template to do something else and tryed to bring up Synaptic Package Manager and got a window in it giving me the same error and then closing down. I then did a quick search on librewolf and tried this:
user@Debian-13-xfce-Business:~$ sudo apt update
user@Debian-13-xfce-Business:~$ curl -fsS https://dl.brave.com/install.sh | sh
curl: (6) Could not resolve host: dl.brave.com
user@Debian-13-xfce-Business:~$ sudo apt purge brave-browser
user@Debian-13-xfce-Business:~$ echo “deb [signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg] https://brave-browser-apt-release.s3.brave.com/ stable main” | sudo tee /etc/apt/sources.list.d/brave-browser-release.list
user@Debian-13-xfce-Business:~$ echo “deb [signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg arch=$( dpkg --print-architecture )] https://brave-browser-apt-release.s3.brave.com/ stable main” | sudo tee /etc/apt/sources.list.d/brave-browser-release.list
deb [signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg arch=amd64] https://brave-browser-apt-release.s3.brave.com/ stable main
As you can see I tried one mentioned above and another online and then tried a couple of different combos of the echo command. I think I need to undo the original echo command I did to fix this but I have no idea how to do that. Any help would be appreciated. Thanks.
I just wanted to switch to debian-13-xfce. All PTSD from first fight from installing software start to comeback. Every bigger change in qubes is 2 week learning curve and makes me want to ditch qubes.
From a start what I do…
Start a debian-13-xfce, run terminal.
Sudo apt install curl
works
sudo curl -fsSLo /usr/share/keyrings/brave-browser-archive-keyring.gpg https://brave-browser-apt-release.s3.brave.com/brave-browser-archive-keyring.gpg
curl: (6) Could not resolve host: brave-browser-apt-release.s3.brave.com
Ah F! I forgot that in last debian-12-xfce I added proxy to install software outside of apt repository.
In debian-12-xfce I go to /etc/apt/apt.conf.d/ and copy to other qube debian-13-xfce a file found there. 95proxy contains Acquire::http::Proxy "``http://127.0.0.1:8082/``";
QubesOS didnt create a QubesIncoming folder… okey.
Sudo nano 95proxy
Not working. Go to forum to cry there. I install brave-browser with following:
Please, dont remind me that template connects with internet and that is dangerous. Is there paranoid-programmers off button? I want templates to be able to install stuff. For me its a waste of life.
Sorry but this is the Qubes OS forum, (you know, that reasonably secure OS )… so I will. Of all the available methods to install brave, you choose the worst one. If you don’t know what you are doing, extrepo is a better option, I’m pretty sure you can use the instructions in this post (replace the name of the browser by brave):
This is not “okey” - it would be a serious bug if true. We’d need to dig
in to what went wrong. In the ordinary case the QubesIncoming folder is
created for you.
What you are doing here is using sudo and the proxy to download the install.sh file, and piping that command through to sh
Environment variables arent generally passed through a pipe command. So
the proxy settings on the left hand side are not there when you try to
run the script. sudo is not passed through redirects either. So you are running the
script as the ordinary user. (In this case the LHS sudo is redundant.)
In this sort of case you either need to set the proxy globally or download the script and edit and adapt it to Qubes. There are easier
ways in this case: in other uses it may be necessary to edit an install
script.
