I want compile to gentoo-minimal, but always failing along the way.
Fails are three pattern.
Error 1:When run emaint or emerge, template is shutdown.
Dom0 terminal’s error message:‘command failed with code:255’.
Error 2:When compile by ‘emerge --ask --verbose --update --deep --newuse @world’ command, compile stop.
Gentoo xterm’s error message:‘Segmentation fault (core dumped)’.
This message frequently appears and stop compile, each time I must run emerge command.
Error 3:Each time I re-run emerge command, I reach cmake package, but compile definitely stop.
Gentoo xterm’s error message:‘emake failed’.
After cmake, emerge never progresses.
How can I succeed?
MyPC
RAM:16GB
CPU:i3 12gen
OS:Qubes OS 4.2.2
