On a Meteor Lake-P using the i915 driver, when I rotated the screen 90° with xrandr --output eDP-1 --rotate right, it would cause a huge delay in painting the screen (other than a 16×1920px chunk on the top edge that seemed to paint immediately).
I resolved this by disabling framebuffer compression:
- Edit
/etc/default/grub - Add
enable_fbc=0to the end ofGRUB_CMDLINE_LINUX= - Run
I experimented with disabled other options (enable_rps, semaphores, enable_dc) but none of those seemed to make a difference.
Hope this is helpful to someone!
