HP ZBook Firefly 15 G7
Pre installation Tasks:
  1. Disable GPU from BIOS
  2. Increase Video Memory to 512 MB
Optional: Disable Bluetooth from BIOS for security,
Enable thunderbolt, port, disk, and any external port protection.
Hi @Zaro and welcome to the Qubes OS community. Since this is your first
post, you probably don’t have the ability (yet) to upload files into the
post – right @deeplow?
If you’d like you could email your HCL report to
qubes-users@googlegroups.com
or if you prefer directly to me:
Sven@SvenSemmler.org
Once I have the actual YML file I can push it into a pull request for
the website.
Thank you!
hello,
I was wondering if you’d be able to help me with installing a Coreboot BIOS on my device.
@Zaro, you should be able to upload the .yml now (just edit your first post and drag-n-drop it).
Please open a new discussion for this and explain the steps you’ve taken already. We try to keep it to one topic per discussion :slight_smile:
Sure. I’ll get to it. I’ll upload the YML as well.
layout:
  'hcl'
type:
  'notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  HP
model: |
  HP ZBook Firefly 15 G7 Mobile Workstation
bios: |
  S73 Ver. 01.03.02
cpu: |
  Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:9b61] (rev 0c)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Device [8086:9b41] (rev 02) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Device 02f0
memory: |
  31963
scsi: |
usb: |
  2
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.0
  xen: |
    4.8.5-32.fc25
  kernel: |
    5.4.107-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
@deeplow I have opened a new topic with the concern of creating a new BIOS on Core boot.
Thank you @Zaro, your HCL report is not part of this pull request:
… and will be visible on the website soon!
