HP ENVY (17m-bw0xxx)
layout:
  'hcl'
type:
  'notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  HP
model: |
  HP ENVY Laptop 17m-bw0xxx
bios: |
  F.14
cpu: |
  Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:5914] (rev 08)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Device [8086:5917] (rev 07) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
  Intel Corporation Wireless 7265 (rev 59)
memory: |
  32508
scsi: |
  SanDisk SDSSDH3  Rev: 20RL
  DVDRW  DA8AESH   Rev: XH6M
usb: |
  1
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.0
  xen: |
    4.8.5-34.fc25
  kernel: |
    5.4.125-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
  • Burned R4.0.4 (xfce) ISO to 8GB stick from linux Mint Ulyssa; booted ISO stick, installed to 64GB USB3.0 stick for 10-day evaluation; successful.
  • Performed dual-boot install next to linux Mint Ulyssa, (just in case).
  • Installed R4.0.4 to 256GB primary partition next to multiple (critical) logical partitions. No insurmountable obstacles not covered by Qubes Documentation or Forum.
    [Original (Mint) partition moot; eliminating w/ no change to Qubes bootloader.]
Parallel mailing list topic: [qubes-users] HCL - HP ENVY 17m-bw0013dx
Have you read yet Templates - Inheritance and Persistence?
According to the FAQ:
Can I install Qubes OS together with other operating system (dual-boot/multi-boot)?
You shouldn’t do that, because it poses a security risk for your Qubes OS installation. But if you understand the risk and accept it, read documentation on multibooting. It begins with an explanation of the risks with such a setup.
From the practical perspective what I would suggest is installing it instead in an external SSD and that way you avoid all the multiple partitions / multiboot issues. Just remember to install it without sys-usb if the SSD is a USB device.
Perfect. Spending some afternoons in the docs is really key to not getting frustrated on Qubes. So many users (including myself) have struggled a lot because they didn’t do that first.
Good luck! :slight_smile:
p.s. Also, if you’re ok with it, could you attach the .yml file of the HCL report? If you need any help on that just reply.
Thanks immensely, Deeplow.
All I needed was to get my proboscis properly vectored.
I’ve added a link in the original post to the mailing-list copy of the new version:
layout:
  'hcl'
type:
  'notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  HP
model: |
bios: |
  F.14
cpu: |
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5914] (rev 08)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation UHD Graphics 620 [8086:5917] (rev 07) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
memory: |
  32508
scsi: |
usb: |
  1
versions:
- works:
  qubes: |
    R4.1
  xen: |
    4.14.5
  kernel: |
    5.15.81-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
During 4.1.1 installation, I used a custom disk configuration, wherein I set / and /home as separate slices. No need to set mount points for keeper (no destroy) ext4 partitions, as was necessary in R4.0.1. After install, sys-net failed to launch:
ERROR: Unable to reset pci device 0000:02:00.1
I had to disable the onboard NIC to get wireless networking to work. In dom0: terminal:
qvm-shutdown --wait --all (Highly suggested)
qvm-pci detach sys-net dom0:02_00.1 qvm-pci attach --persistent --option no-strict-reset=true dom0:02_00.1
Also, increase Fedora36 Initial Memory to 1000MB or initial upgrade will fail.
Thank you @9thCat for your HCL report, which is online now!
Thanks Sven, it’s good to be back.
I’ve got one more that is in work: an R.4.1.1 install on my Dell Optiplex 9020 studio tower. Looking to fat-thumb an AV-MX linux qube to handle my PreSonus AudioBox 1818VSL USB 2.0 recording interface.
Regards,
Del Riker
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  HP
model: |
bios: |
  F.14
cpu: |
cpu-short: |
  FIXME
chipset: |
chipset-short: |
  FIXME
gpu: |
gpu-short: |
  FIXME
network: |
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 12)
  Intel Corporation Wireless 7265 [8086:095a] (rev 59)
memory: |
  32508
scsi: |
usb: |
  1
certified:
  'no'
versions:
  - works:
    qubes: |
      R4.2.0
    xen: |
      4.17.2
    kernel: |
      6.1.62-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
An extraordinary O/S on an outstanding laptop!
I installed an aftermarket 2TB SSDD a few years back. During R4.2 installation, I opted for a custom disk configuration, wherein I set / and /home as individual partitions of 300GB and 32GB each, more than enough acreage for most interests.
I decided to go for a debian-12 system configuration over the fedora-38 system I used with R4.1.2.
  • I use WiFi exclusively.
    As with R4.1.x, sys-net fails to start on first boot:
    In dom0: terminal, disable the onboard NIC to get wireless networking to work.:
    Restart: sys-firewall & sys-net should take off…
  • USB Mouse inactive on login:
    In dom0 terminal:
    vi /etc/qubes-rpc/policy/qubes.InputMouse
    Add the following line:
    sys-usb dom0 allow
    Save and restart.
I’ve maintained separate extended disk partitions for dedicated file categories on all my systems for over 20 years, originally FAT32 and now steadfastly ext4:
Data: Anything non-graphical derived from the Internet, which can be replaced if necessary:
EXEs, ISOs, PDFs, ZIPs, TARs, etc.
Files: Any and all content I originate, without exception.
Grafx: Graphical Internet content: wallpapers, bitmaps, etc.
I leave them untouched during disk configuration (no mount point set), then mount them persistent according to function-specific qubes.
Thank you for HCL report and additional information. Can you please also fill a detailed report based on this template:
Example of user providing the answers is here. The more information the better, it may be helpful to other users, thank you.
Thanks for HCL report. I just submitted a pull request to add it to the HCL database.
Best,
Flavio
