HP ENVY (17m-bw0xxx) [Merged #2]
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  HP
model: |
  HP ENVY Laptop 17m-bw0xxx
bios: |
  F.14
cpu: |
  Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5914] (rev 08)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation UHD Graphics 620 [8086:5917] (rev 07) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 12)
  Intel Corporation Wireless 7265 [8086:095a] (rev 59)
memory: |
  32508
scsi: |
  SanDisk SDSSDH3  Rev: 20RL
  DVDRW  DA8AESH   Rev: XH6M
usb: |
  1
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.0
    xen: |
      4.17.2
    kernel: |
      6.1.62-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
An extraordinary O/S on an outstanding laptop!
I installed an aftermarket 2TB SSDD a few years back. During R4.2 installation, I opted for a custom disk configuration, wherein I set / and /home as individual partitions of 300GB and 32GB each, more than enough acreage for most interests.
I decided to go for a debian-12 system configuration over the fedora-38 system I used with R4.1.2.
  • I use WiFi exclusively.
    As with R4.1.x, sys-net fails to start on first boot:
    In dom0: terminal, disable the onboard NIC to get wireless networking to work.:
    qvm-shutdown --wait --all (Highly suggested)
    qvm-pci detach sys-net dom0:02_00.1
    qvm-pci attach --persistent --option no-strict-reset=true dom0:02_00.1
    Restart: sys-firewall & sys-net should take off…
  • USB Mouse inactive on login:
    In dom0 terminal:
    vi /etc/qubes-rpc/policy/qubes.InputMouse
    Add the following line:
    sys-usb dom0 allow
    Save and restart.
I’ve maintained separate extended disk partitions for dedicated file categories on all my systems for over 20 years, originally FAT32 and now steadfastly ext4:
Data: Anything non-graphical derived from the Internet, which can be replaced if necessary:
EXEs, ISOs, PDFs, ZIPs, TARs, etc.
Files: Any and all content I originate, without exception.
Grafx: Graphical Internet content: wallpapers, bitmaps, etc.
I leave them untouched during disk configuration (no mount point set), then mount them persistent according to function-specific qubes.
3 posts were merged into an existing topic: HP ENVY (17m-bw0xxx)
