During 4.1.1 installation, I used a custom disk configuration, wherein I set / and /home as separate slices. No need to set mount points for keeper (no destroy) ext4 partitions, as was necessary in R4.0.1. After install, sys-net failed to launch:
ERROR: Unable to reset pci device 0000:02:00.1
I had to disable the onboard NIC to get wireless networking to work. In dom0: terminal:
qvm-shutdown --wait --all (Highly suggested)
qvm-pci detach sys-net dom0:02_00.1 qvm-pci attach --persistent --option no-strict-reset=true dom0:02_00.1
Also, increase Fedora36 Initial Memory to 1000MB or initial upgrade will fail.
The .yml file:
Qubes-HCL-HP-HP_ENVY_Laptop_17m_bw0xxx-20230103-173007.yml (948 Bytes)
The guts:
layout:
‘hcl’
type:
‘notebook’
hvm:
‘yes’
iommu:
‘yes’
slat:
‘yes’
tpm:
‘unknown’
remap:
‘yes’
brand: |
HP
model: |
HP ENVY Laptop 17m-bw0xxx
bios: |
F.14
cpu: |
Intel(R) Core™ i7-8550U CPU @ 1.80GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5914] (rev 08)
chipset-short: |
FIXME
gpu: |
Intel Corporation UHD Graphics 620 [8086:5917] (rev 07) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
Intel Corporation Wireless 7265 (rev 59)
memory: |
32508
scsi: |
SanDisk SDSSDH3 Rev: 20RL
DVDRW DA8AESH Rev: XH6M
usb: |
1
versions:
- works:
‘FIXME:yes|no|partial’
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.81-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
[/quote]
The .yml file:
The guts:
layout:
‘hcl’
type:
‘notebook’
hvm:
‘yes’
iommu:
‘yes’
slat:
‘yes’
tpm:
‘unknown’
remap:
‘yes’
brand: |
HP
model: |
bios: |
F.14
cpu: |
cpu-short: |
FIXME
chipset: |
chipset-short: |
FIXME
gpu: |
gpu-short: |
FIXME
network: |
memory: |
32508
scsi: |
usb: |
1
versions:
- works:
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.81-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
