How to view, edit, and remove saved networks? Can Qubes connect to WPA3?
How can I view, edit, and remove saved WiFi networks? Also, can Qubes connect to WPA3?
Did you try to right-click the Network Manager icon (on the panel, top-right) and select “Edit connections…”?
This did the trick. Thank you so much!
