How to verify Qubes Master Key with Android
Hi, everybody. I’ll install Qubes Os on a Freedos laptop. But this issue of signature verification makes it difficult. I don’t have any other computer, I only have an android phone. I couldn’t trust Openkeychain because I heard that it’s not updated anymore. Can you help me on how to verify this signature?
Also, I’ll use Etchdroid to load the ISO file, does this work?
Thank you in advance for your responses.
Could you use adb to get shell access to your phone. On android there is an app called Termux that can help to run shell commands.
Appreciate your help. Using Termux solved the problem.
