Hello everybody
There are various types of Qubes, such as Work Qubes, disposable Qubes, vault Qubes, etc., but what kind of abilities do they each specialize in, and how should they be used? What I especially want to know is what an untarasted Qube can do and how it should be used. Currently I’m using the disposable whonix, but if I can change the untarasted Qube template cube to whonix or create a whonix template, I’m thinking of changing to that. I’m not very good at using it yet, so I’d like to know how it works.
- App qubes configured to prioritize security by compartmentalizing tasks and types of data:
work,personal,untrusted, andvault. (There is nothing special about these qubes. If you were to create a black qube and name itvault, it would be the same as the pre-configuredvaultqube. They’re just suggestions to get you started. )
Ok, there are no particular differences or characteristics other than the name. I did not know that. Thank you apparatus, you was very helpful in answering all my questions.
