Refat
January 14, 2023, 11:11am
21
It’s working now. Thanks a lot
You are welcome. You can mark the post which helped you as a solution, to help other new users.
Refat:
It’s working now.
Note that you do not get the best security Qubes can offer if you do not have sys-audio.
you can make Bluetooth work in 4.0. However, AFAIK it won’t be secure to use it for audio, because PulseAudio is not isolated from dom0. I don’t know the technical details, I have only read the link I provided.
It has been some time since the last design post about Qubes. There have been some big changes happened, and it took us a little while to find people best suited to write these articles. But, as you can see, the victims volunteers have been found....
opened 06:34PM - 06 Jan 16 UTC
T: enhancement
P: major
release notes
C: audio
Currently, PulseAudio is running in the VMs and passing all the audio data over … the network to a PulseAudio instance running on dom0.
However, this provides an unnecessary possibility for attacks on dom0, perhaps even between domU instances.
I believe that a similar set-up to NetVM can be equally powerful without providing this possibility for an attack.
I must say, this works very beautifully and is very user friendly. I've had Linux distros running on bare metal work less well out of the box with audio.
Hi, I would like to configure a minimal template for sys-audio instead of the default fedora-34-xfce.
I installed qubes-core-agent-usb , qubes-core-admin-client , and pulseaudio-gui-daemon-qubes,alsa-utils,pavucontrol in deb11-audio, which was a clone of debian-11-mimnimal, and changed the pre-configured sys-audio’s template to deb11-audio. I’m happy to see audio streams coming from other qubes in pavucontrol .
However, I couldn’t use any physical audio device, including my soundcard (Realtek …
enmus
January 16, 2023, 8:33pm
25
I’m posting this link here if people have issues when using bluetooth (after the device is recognized and blueman and/or blueZ are successfully installed).
https://bbs.archlinux.org/viewtopic.php?id=270465
If the solution cannot be found there, I doubt it can be anywhere else.
