Could (have?) you try/tried and pick “fedora 36” as the template for your sys-net?
FML - that did the trick! (Using fedora-37 tho).
Thank you @cayce & @ChrisA for the patience and support - you onboarded another Qubes enthusiast
FYI - I had to install Qubes from scratch again and this issue seems to be reproducible for me. Switching over to Fedora is the solution, good to know!
How to troubleshoot “no WiFi” -
journalctl -b - look for errors or warnings reHow do you install with no WiFi? See if you can use Ethernet port.Most WiFi
routers come with Ethernet ports and provide a cable (in my experience).
If this isn’t possible, if you have access to another machine, download
the packages there, and transfer to USB stick. Move the stick to your
offline machine, attack it to your template using qvm-devices tool, and
install.
Steps 2 and 3 may provide some information. You can search for that
error message and will likely find what to do.
If all you are interested in is a quick fix, run step 5 first, or
after step 1.
Sometimes simply switching template is enough.
