I hear you I had 12gb on my first good laptop, could you elaborate on what you mean. I use debian xfce it is so cheap in memory that I can run it with 400mb ram.
16GB should be enough, i have that as well. Unless you want to do multiple heavy tasks at the same time.
More secure? Qubes OS is already secure enough. Many people making their Qubes more secure, is more like a hobby than a necessary. If your main goals is security, i would install Kicksecure template using Dom0 for non-tor and VPN.
And for Tor, AppVMs based on Whonix 18 are secure as well. If you think you are not advanced and you play around with advanced stuff, you will make your system less secure.
Yes but RAM is just one thing, not always the most important factor. I think in your situation it has also much to do with the strength of you processor.
If you were going to install liteqube you might as well just download mirage-firewall and install that on its own. Less cpu and less memory its a win win. Personally I would also make sure there were no preloaded disposables, I know they have there place but with limited ram I personally would turn them off. This may sound obvious but you can also just shut sys-whonix down if you are not using it. Obviously if you are using the tor-browser or updating then you need it running but then shut it down.
Not sure about this one but if you are not using a usb keyboard and mouse you could shut sys-usb down if you are not using it (not sure about that one hopefully someone else can clarify that one). Obviously you would need to restart it if you put a usb device in but needs must.
I personally dont use wifi so things might be different if you do
2 things:-
If you install liteqube mirage-firewall would have been installed by default (I believe), (although there is a “normal” linux one also) but which one is more secure from that particular source?
is mirage-firewall more or less secure than the liteqube offerings?
I am not a security expert just explaining the above points that you seem to trust liteqube and willing to install it but question mirage-firewall.
I dont know the answer I will let someone more knowledgeable about the subject to answer that question, but looking at he above points it is probably at least equally as good as the liteqube alternative.
I hope that doesn’t sound nasty as it is not meant to be.
How much RAM do you have assigned for:
dom0
Whonix g/w
sys-firewall
sys-usb
sys-net
others?
All of those can probably be reduced.
Replace sys-fw with mirage if you can
try 500MB for whonix g/w or go lower. (if you use it)
Dom0 can be reduced try 2, if not then 3 GB should be plenty.
If you have a 2025 processor you may be able to Increase the no. CPU cores on your browser qube.
When RAM is too less you will probably see boot errors, glitches and cpu ballooning to 100% then increase it until you find the sweet spot.
From my experience Debian uses less overall than Fedora and Debian minimal even less if you know how to use it.
p.s I personally found kicksecure and whonix ws to be quite resource hungry and very difficult to customize / minimize. I also don’t know if you are experiencing overheating which can lead to throttling which can also effect performance. That can be something to check. Good practice to use some kind of monitoring so you can see what is going on temp/mem/cpu/process wise.
Everything from browsing,notes, even more medium heavy stuff. One thing to point out not every .Deb or package works good, some stuff like light cad or a decompiler freezes instantly upon opening. For an appvm xfce is the best, and for other heavy duty apps use standalone.
well its a bit like threat modeling, you tweak your system to what you use. @unman gave me a usefull tip once with text browsers. With Qubes you should be able to get by with a x230 on 16GB of RAM, but don’t expect it to do gaming (unless you like TTY gaming) or video editing or even youtubing. Model your setup to what you need to do and if you need to do more, then maybe re-evaluate your choice of OS.
huh? the original purpose of Liteqube was for exactly that, making it work on ancient low specs hw? Anyways, the point remains.. What do you use it for… Without that you will always run into problems.
Liteqube was created in 2017 to run Qubes on a rather low-spec GPD Win 2 (Core m3-7Y30, 8Mb RAM). Taking 2Gb of RAM to run dom0 and fully torified set of services, it allowed me to use a device with 8MB of RAM quite comfortably.
