No, i must use this workaround since years for my ungoogled-chromium Browser under Debian and Fedora. The error “Could not unzip extension” usually occurs when updating the uBlock add-in, but not always.
You can find more details here: How to Manually Install Extensions (Ungoogled Chromium) | Avoid the Hack (avoidthehack!) and GitHub - NeverDecaf/chromium-web-store: Allows adding extensions from chrome web store on ungoogled-chromium. Also adds semi-automatic extension updating.
Maybe, most of the time an update of the add-ins works without problems, but sometimes not. So far I have not been able to recognize a pattern.
solene
April 20, 2024, 11:38am
22
I’d recommend you to not use the flatpak version, instead use the official brave RPM repository, Installing Brave on Linux | Brave
this is the genuine upstream version while the flatpak one isn’t managed by brave
installing extensions from the store works out of the box
it will update as part of Qubes OS updates, no extra work
I used ChatGPT to generate the command and this is the output I got:
[user@work ~]$ brave-browser-extension --install-extension=<dcejoghgeeihdfikhfggnkgpkojgennb>
bash: syntax error near unexpected token `newline'
[user@work ~]$
In either case, I have managed to successfully install the extension. Thank you though!
I reinstalled Brave following their Fedora steps and Bitwarden installed just fine on that version, thank you for pointing this out!
solene
April 20, 2024, 1:37pm
24
this didn’t work because your command input had character <
and >
without quotes, so bash took for the symbols that are used to redirect output or input.
glad you solved this
