qn00r3
1
Hello, I have three questions, please tell me:
- How to increase dom0 RAM?
- How to disable swap in dom0?
Is it enough to comment out the line in the /etc/fstab file:
#/dev/mapper/qubes_dom0-swap none swap defaults,x-systemd.device-timeout=0 0 0
- How to disable swap in a specific virtual machine?
Is it enough to comment out the line in the virtual machine template in the /etc/fstab file:
#/dev/xvdc1 swap swap defaults 0 0
Add this line at the end of in grub config /etc/default/grub and change dom0_mem=max value:
GRUB_CMDLINE_XEN_DEFAULT="$GRUB_CMDLINE_XEN_DEFAULT dom0_mem=max:4096M"
And regenerate grub config:
This should be enough, but you can try it to make sure.
qn00r3
3
After I disabled the swap file in dom0:
Commented out the line in the /etc/fstab file:
I have a block device (qubes_dom0-swap):
[user@dom0]$ qvm-block
BACKEND:DEVID DESCRIPTION USED BY
dom0:dm-5 qubes_dom0-swap
Is there a way to prevent the block device (qubes_dom0-swap) from appearing in Qubes Devices ?
Check if this volume is used for swap using this command:
swapon -s
You can remove this volume if you don’t plan to use it for swap anymore:
lvremove /dev/mapper/qubes_dom0-swap
