Sven
October 8, 2021, 11:47pm
21
entire system froze […] when using kernel version 5.4.x … never with v4.19.x […] I can no longer reproduce this with the latest 5.4 kernel on the T430.
Well, it took longer… but it’s still happening. Ran the salt-based update while also shutting down a large HVM. Then it happened: total freeze incl. mouse … everything. There is nothing in journalctl. Just “— reboot —”
Switching back to 4.19 kernel.
I now tried Qubes 4.1 RC1 and the system works flawlessly - not a single freeze anymore (with Samsung 870 EVO).
Clodius
November 19, 2021, 5:00pm
23
how do you switch back to kernel 4.19?
I just updated at T540 and lost the wifi networking also, freezes on the desktop,
Clodius
November 19, 2021, 5:21pm
24
00:17.0 SATA controller [0106]: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] [8086:a102] (rev 31) (prog-if 01 [AHCI 1.0])
is my Samsung Evo 8xx series , also freezing
kernel 5.10.76-1
rc2 I believe
Sven
November 19, 2021, 6:04pm
25
@Clodius :
sudo qubes-dom0-update kernel-419 kernel-419-qubes-vm
Then reboot and select in grub.
Clodius
November 19, 2021, 6:39pm
26
hmm, it can’t find that package
and don’t really see anything with
$dnf search kernel
Clodius
November 19, 2021, 8:36pm
27
hmm all this time with my Evo 840 I’ve not been using any TRIM
per lsblk there are 0 's for the parameters instead of a “non-zero”
somehow not sure I want to mess with dom0, unless there is some standard for fstrim in dom0?
sigh
Sven
November 20, 2021, 1:43am
28
Clodius:
$dnf search kernel
That’s because dnf search in dom0 can only see what’s already installed, it doesn’t have access to the internet and cannot download any catalog.
The command I posted works in R4.0 … if you are on R4.1 I am not sure kernel 4.19 is still supported there.
Clodius
February 23, 2022, 2:36am
29
fwiw, i’m on the latest 4.1 stable, just had to hard reboot 4 times, after system froze repeatedly, no idea why…
however, without any dom0 updates, previous to this it was up for 8 days straight, not seeming so ‘stable’ to me yet
still no idea how to trouble shoot
I have a Samsung 870 EVO and I am experiencing freezing and big performance issues too. Perhaps this is the issue I am also having.
Has this issue completely resolved itself?
Yes, I’ve never seen a freeze again since I switched to Qubes 4.1 and BTRFS. I didn’t test whether I would have actually needed BTRFS, so maybe just using Qubes 4.1 would have worked already.
