How to d-st-upgrade Qubes
Hello. How to dis-upgrade Qubes OS with --keep-runing 3 qubes in a chain (sys-net, sys-firewall and sys-whonix)? I can get only the first one stated, whichever it is.
--keep-running                     List of extra VMs to keep running during update (comma separated list).
                                   Can be useful if multiple updates proxy VMs are configured.
--keep-running sys-net,sys-firewall,sys-whonix
Thanks, but that doesn’t work, with or without commas… Did you personally used it?
No, I didn’t use it.
Do they shut down after you run the command with --keep-running?
Post the exact command that you run.
Also make sure that you use --keep-running and not --keep-runing.
You were right, thanks. I was putting spaces after commas…
