Good morning everyone,
So I would like that backup a file to one of my internal SSD’s. I have it mounted, I have it added to the “Domain”. I want to move it from a “Domain” to the other internal SSD so I will have to copy/cut and paste to the folder inside of this SSD. Obliviously “click & drag” doesn’t work,LOL. But I can’t copy/paste this file to the other internal SSD. I do the (ctrl+shift+c) to copy…I see the clipboard popup and then I do the (ctrl+shift+v)…I see the clipboard popup. Then I go to the other internal SSD to paste and NOTHING!! Paste isn’t a option.
How do I do this…Move a file from a “Domain” to another internal SSD so I can have backups?
Mind you these other SSD’s are part of my SAS raid drive card and I can see them,mount them, copy from them to the Qubes desktop BUT I can not copy/move from Domains to them,Why???
Or maybe I’m done omg this hole process wrong. Can someone explain or help out?
Also for security reason I have the ability to power these internal SSD’s on/off. So once I’m done doing anything I need to do they are off. So when they are off the computer let alone Qubes doesn’t even know they exist, of course until I power them on again. And this powering on/off of these internal SSD’s is done by “hardware” not “software”…
I figured out what I could do…I will have it “screenshot” stuff. That’s the only way I can save from dom0 to these internal drives.
But I can’t view whatever I have saved to that drive… Right click on it, "open with other application, chose application and nothing…
So my question is…
Why “attached” other internal drives to active (appVM’s or templates) if I can’t access/use them??
After I mount the other internal SSD. I go up to the right corner and click the icon, hit the plus sign to attach his drive,it attaches. Then I see displayed…
dom0:sdk1 - Samsung_SSD (drive name) (debian-10). But I can’t do anything move,copy,paste to it from Domain,Template. So what is the purpose of this feature??
