Good morning,
I need to copy a “folder” from dom0 to domain. I know that…
qvm-copy-to-vm (target_vm) file
will copy just a file.
I want to copy a fold
What is my terminal cmd please?
Thank you all
Good morning,
Thank you all
@B-ryr
Make a compressed file that contains a copy of the folder contents and move it to your target VM using something like:
tar -czvf move_this.tar.gz /path/to/folder/* && qvm-copy-to-vm <target_VM> move_this.tar.gz
[If you are compressing files in the root directory, use sudo before tar.]
[The * in the folder path means “everything inside the folder”. && means wait until the first command is done before moving to the second command.]
In your target VM, go to ~/QubesIncoming/dom0 and decompress the file with:
tar -xzvf move_this.tar.gz
or open the file manager and double click on the file.
No, it can copy folders just fine.
Good grief… thank you.
Thanks guys I’ll give it a go in the morning and let you know.
Well for some reason it’s not working anymore and strange things is I have done it before for files
Maybe I am doing something wrong…
