Hi.
Qubes 4.0
Let’s say I need to do something like this:
ip r del default
ip r add 8.8.8.8 via <ip eth0 interface>
Is it okay to do this in a file /rw/config/rc.local?
For good, need something like /etc/network/interfaces
Hi.
Qubes 4.0
ip r del default
Hi @joreke . Have you checked the docs? Specifically the following
Yes, I looked at this documentation and didn’t find an answer there.
There is an example here https://www.qubes-os.org/doc/config-files/ - /rw/config/network-hooks.d/hook-100.sh
But it didn’t work for me.
You mean it did nothing? Post the contents of your file.
Check out the use of bind-dirs: https://www.qubes-os.org/doc/bind-dirs
Here is my file, but it doesn’t work. Maybe it’s the parameters that are passed? Does it accurately transmit ‘online’ when VM starting?
chmod +x /rw/config/network-hooks.d/hook-100.sh
#!/bin/bash
command="$1"
vif="$2"
vif_type="$3"
ip="$4"
case "$command" in
online)
ip r del default
ip r add 8.8.8.8 via ${ip}
esac
And thanks for the link. create a directory and a file in it is not enough( /rw/config/network-hooks.d/hook-100.sh)?
That script is only called in a netvm - is the qube you are working on a
netvm?
Do you mean that?
netvm
Property type: VM
To which NetVM connect. Default value (–default option) will follow system-global default NetVM (managed by qubes-prefs). Setting to empty name will disable networking in this VM.
In qube (sys-destroy-route-qube) has in properties netvm (sys-firewall). But he himself is not netvm.
Yes - as stated in the docs that script is only called in a netvm.
Since sys-destroy-route-qube is not a netvm the script will never be
called.
Thanks.
Works through /rw/config/rc.local.
Is it correct to place these commands in this file?
