How to allow inbound UDP to a single qube in a secure way?
The goal is to stream content from my camera to a single qube. The camera provides a Wi-Fi network and a usb Wi-Fi adapter will be used just for the purpose to connect to the camera Wi-Fi. The camera sends a live view via UDP. It seems incoming UDP is blocked by default and I don’t know enough about firewalling and security in Qubes OS to unblock it in a secure way.
Questions:
  • what’s the best way to connect to the camera Wi-Fi? Should I use a separate sys-net or sys-firewall for it?
  • how do I allow incoming UDP for this purpose in a secure way?
Edit:
Additional info:
The app I am using works similar to this one: GitHub - wegel/lumixcam · GitHub , i.e. connect to the camera’s Wi-Fi, then run the app.
I would recommend to
  • create a separate sys-net,
  • add you USB wifi to this qube,
  • and setup the inbound according to the guide linked above.
In this way all other qubes will be intact, and the whole new inbound path would be separated from the rest.
You do not open your firewall for incoming when you watch UDP TV streams, so I don’t see why you should do it for a camera. All you likely need is to connect to the UDP stream (IP_ADDRESS:PORT), e.g. using vlc or mpv, from the qube. You can restrict connections to UDP traffic from host with IP_ADDRESS and certain PORT like this:
qvm-firewall --raw MYQUBE add --before=0 action=accept proto=udp dsthost=<IP_ADDRESS> dstports=<PORT>-<PORT>
Thank you @Atrate and @Zrubi for your answers!
I am still trying to understand things and it gets confusing pretty fast. E.g. the second sentence on Firewall — Qubes OS Documentation says
By default there is one default net qube used as firewall …
I always thought that the default sys-net is a net qube (just from the name of it) and sys-firewall is a firewall qube but that doesn’t seem to be the case.
Thank you, @qubist , your answer came in while I was just writing this post. So I will stop reading for now and try your suggestion first. It seems a lot easier than the other suggestions.
Yeah… the ‘other suggestions’ are assuming you know what you asking for :wink:
So, if you just want to receive the video stream from your camera that’s NOT an inbound connection…
And I thought it was pretty clear that I know nothing :wink:
Sorry if my questions weren’t clear. I am still trying to understand things. And I may still need your suggestions.
Do you mean “allow” instead of “restrict”? Because as it is now, the streaming from the camera to the qube is blocked by something.
action=accept as in the rule. To make it restrictive you also need to add action=drop as a last rule.
If the command line is confusing you, you can do the same through the GUI. Open the settings of the qube and go to “Firewall rules” tab, Limit outgoing connections to… press the ‘+’ button and set your config.
Hmm, I don’t want to limit any connections (for now), just trying to make it work.
Rereading that again this may be a different setup. I guess in the case of the TV both devices are connected to the same local network and you can access the UDP TV stream over this network?
In case of my camera it is the camera that provides the Wi-Fi network, and the qube that connects to it.
Now I’ll continue reading and trying to understand things …
More info or links are still welcome :slight_smile:
Additional info:
It doesn’t matter if the address of the streaming host is 10.10.10.10 (LAN) or 55.66.77.88 (Internet). This is non-Qubes specific. As long as the IP address of the camera is not in the address set used by qubes (10.137.x.x), you should be fine.
Connect to the camera using your WiFi adapter. As noted by others, you can create a separate sys-net-2 and sys-firewall-2, so it does not interfere with your regular Internet connection. Then you set the NetVM of your client qube to sys-firewall-2 and connect to the camera using sys-net-2, then access the stream using your player of choice. The firewall setup I suggested is an additional security measure, so you can be sure that the client qube can connect only to the camera.
While I still don’t understand everything (will continue to read) I got it to work with the script from @solene and a new sys-net-2 and sys-firewall-2.
So it was indeed necessary to open the UDP port to make it work. Without it it did not work.
One problem I am still facing: the UDP port is different each time, the IP stays the same though, and no other machine on my local net has this IP. Would it be possible to adjust the script to allow the IP with any UDP port?
Doing things mechanically without understanding is dangerous (especially in dom0). I have not seen this script and I don’t know what it does, so I can’t answer your question.
The script is from the second post of this thread - [Qubes OS 4.2] Easily NAT qubes port to external network
Also thanks for the warning. I looked at the script to get an idea of what it does before running it.
Solved the problem by telling the app to use a specific port.
Final question: what would be the security implications if I use the default sys-net, sys-firewall instead of sys-net-2, sys-firewall-2?
Glad to know you found the way.
sys-net is distrusted. sys-net-2 can also be distrusted but at least you use it only to connect only to one specific device.
Also having a separate qube will allow you to easily control the connection to the camera and to the Internet separately.
sys-firewall-2 is necessary because one firewall qube cannot have 2 NetVMs.
I have now marked a post as a solution, but there was useful info in other posts, too. Thank you everyone who replied in this topic!
