It would be neat if we could allow access to sys-audio to only select VMs, I don’t see any reason why sys-net or sys-usb should have access to it. Does anyone know how this can be achieved?
That is completely correct logic I’m using as well.
So, in dom0 I’m using
$ qvm-prefs default_audiovm ‘’
to set none as default audiovm, and then manually set sys-audio for each desired qb. For example, for disposable browsing qubes, it is needed to set sys-audo as default audoivm to their dvm template
$ qvm-prefs f38-firefox-dvm(template) audiovm sys-audio
You mean qubes-prefs default_audiovm ''? Since qvm-prefs default_audiovm '' throws an error.
Let’s say you run:
How would you revert it?
