How to add applications to this menu with custom/official icons? as appimage has non.
How to add/remove an application in the default apps menu? to add it to qubes easily
Your second topic is a duplicate, right?
What do mean by my second topic?
Also can you simplify this guide to me? as I find my self lost as it is complicated for me
That one:
Where are you lost? The first step for your Appimage is to check if it’s available inside the qube. If not, it may be a common problem related to Appimages, not to Qubes OS. Once this is completed, we can progress on the Qubes part.
I wrote my own guide before figuring it was already documented, maybe it will sound easier for you?
