How can I find how sys-net is working and maybe make some changes into it.
e.g.:
- create a sys-net-wifi that will work only with WiFi
- create a sys-net-cable that will work only with cable
I saw sys-net is using tinyproxy on port 8082 … is this something that should be there?
What I’d like to do is having e.g. internet from wifi but create a lan with another PC via cable and communicate with that one via cable and go to the internet via wifi
so make general qubes use sys-net-wifi and some specific qubes sys-net-cable
Right now, how things are configured, I can’t do so as if I’ll connect to wifi and then to the cable I’ll lose internet connections [and I’ll have only the communication with the pc connected via cable]
