How is usrlocal mounted in 4.3?
The mount point is no longer in fstab, and usr-local.mount is called elsewhere. While playing with minimal template I must have deleted something vital by accident – now home does mount. but usr-local does not and qubes-bind-dirs service cannot start because of unmet dependency. How do I diagnose it? Is it documented somewhere?
Not sure if that helps to piece it together, but that commit and the corresponding pull request is where it changed for R4.3.
Pretty strange. Still have no idea how come my home mounts automatically but usrlocal needs manual start :confused:
I essentially had to stop using /usr/local for installing code I had written myself (I was actually installing to whatever directory gets linked to /usr/local/bin–I’m for some reason mentally blocked and can’t recall its name right now). A few of my AppVMs would fail to mount it, for no apparent reason–at least not before I created named disposables off of them. And this was on 4.2.
I eventually just created /usr/custom and installed that stuff there in my templates, then softlinked them all to /usr/bin. Perhaps a similar approach could be a workaround for you.
