Initially, I separated the colors of the qubes to make them less confusing, but as the number of qubes increased, I started using the same colors more often.
Therefore, I decided to categorize them based on safety, but I’m struggling with the criteria for colors other than black and red, as they are vague.
The way it’s described in the docs is something like: (scale)
Red - Ultimately Untrusted
Orange
Yellow
Green - Trusted
Blue
Purple
Black - Ultimately Trusted
However, I use the US classified documents standard, which is:
Yellow: Top Secret/SCI
Orange: Top Secret
Red: Secret
Blue: Confidential
Purple: Controlled Unclassified Information
Green: Unclassified
Black: system stuff, like templates. (not part of regular coloring)
I just do it this way because it makes sense for me, but you can do it your own way. The general idea, which you can also take or leave, is to color based on the trust level or sensitivity of your qube.
black: offline with no external files, nothing special
blue: see below
yellow: default level when online
orange: see below
red: see below
Then I use a level behind if any of these things happens:
the qube is interacting with other qubes, especially if receiving data, files
the qube uses some applications not installed with the default distribution repos (depending on the method, it could immediately decrease the level to red)
the qube downloads things on the web
the qube is connected to some peripheral (i.e. a phone)
