I would either wait for sometime and try again, or would comment in fasttrack source in the sources list so to be able to update template from other sources, and then investigate what could go wrong with fasttrack.
I tried to follow for what @51lieal suggested, but I canât install whonix from the qvm-template-gui
. I tried to select both the whonix-ws-16 and whonix-gw-16 and hit âapplyâ, but when the âinstalling templatesâŚâ window pops up, I immediately have 100% and nothing is listed and thereâs only option to click âokâ.
try left clck and hold down in the template you wanr, then release in install, after that click apply
That doesnât do anything. Besides, it does imitate installation when I click on âapplyâ, it just doesnât install anything. Just 100% and thatâs it. nothing is added
Operating System Software and Updates chapter fasttrack repository issues in Kicksecure wiki
(Whonix is based on Kicksecure.)
You could found that with a search engine query with the following or similar search term:
site:whonix.org fasttrack is not valid yet (invalid for another
