How do i upgrade whonix gs and ws -16 in Qubes 4.1 exactly step by step?
And what templates should i have if i run qubes with debian as the ground template? I choose debian when setting up qubes in the install meny.
I messed them up after reading some issues with on how to update whonix just now…
I have this error right now:
Updating whonix-gw-16
Error on updating whonix-gw-16: Command ‘[‘sudo’, ‘qubesctl’, ‘–skip-dom0’, ‘–targets=whonix-gw-16’, ‘–show-output’, ‘state.sls’, ‘update.qubes-vm’]’ returned non-zero exit status 20.
whonix-gw-16:
Function: pkg.uptodate
Result: False
Comment: E: Release file for tor+https://fasttrack.debian.net/debian/dists/bullseye-fasttrack/InRelease is not valid yet (invalid for another 1h 35min 13s). Updates for this repository will not be applied.
Started: 14:24:44.907295
Duration: 3668.091 ms
Changes:
Function: cmd.run
Result: False
Comment: Command "/usr/lib/qubes/upgrades-status-notify" run
Started: 14:24:48.579178
Duration: 3300.333 ms
Changes:
pid:
1838
retcode:
100
stderr:
stdout:
Summary for whonix-gw-16
Succeeded: 0 (changed=1)
Failed: 2
Total states run: 2
Total run time: 6.968 s
Updating whonix-ws-16
Error on updating whonix-ws-16: Command ‘[‘sudo’, ‘qubesctl’, ‘–skip-dom0’, ‘–targets=whonix-ws-16’, ‘–show-output’, ‘state.sls’, ‘update.qubes-vm’]’ returned non-zero exit status 20.
whonix-ws-16:
Result: False
Comment: E: Release file for tor+https://fasttrack.debian.net/debian/dists/bullseye-fasttrack/InRelease is not valid yet (invalid for another 1h 30min 39s). Updates for this repository will not be applied.
Started: 14:29:18.489082
Duration: 4827.094 ms
Changes:
Function: cmd.run
Result: False
Started: 14:29:23.320199
Duration: 3784.066 ms
Changes:
pid:
1843
retcode:
100
stderr:
stdout:
Summary for whonix-ws-16
Failed: 2
Total states run: 2
Total run time: 8.611 s
And the templates looks like this:
The default-mgmt-dvm used to have debian 11, and now has fedora-34. Still error…
whonix-ws-16-dvm have fedora 34 now, used to have debian.
How do i update whonix exactly in qubes 4.1? Any step-by-step guide? It don’t work by default… So someone must have solved it? Or is it an issue still? Solved? I searched but missed the answer… Solution. Thanks!
