I have just discovered that Linux (or at least Fedora-37) has five possible states of the root password. My question therefore resolves into which is the Qubes default of …
State
passwd -l root
Password Exists
Login Behavior
Passwordless Root
No
No
No direct root login
Root Account Locked
Yes
Yes/No
Root Enabled with Password
No
Yes
Login as root allowed
Root with Keys Only
Yes
No
Key-based root login only
Root Completely Disabled
Yes
No
Root login fully blocked
I clearly messed with things way above my Linux knowledge, so any advice (e.g. Don’ts) before I start experimenting tomorrow would be appreciated.
I think Qubes is either the first or the second of those 5, but I think it probably doesn’t matter too much.
You should still have passwordless ‘sudo’, because the sudo command takes care of it.
I don’t know if ‘su -’ normally works without password input, but if you need a root shell then you can simply type ‘sudo su -’
As for getting back to no password, a quick look at ‘man passwd’ suggests that ‘sudo passwd -d’ could be the command to run, although I would test it first in a disposable.
Thanks phceac, for suggesting I try it in a disposable. I keep forgetting how easy and quick it is to generate these with Qubes, (and then just kill them if anything goes wrong) .
I have also realized that I have a second, (unmodified) Qubes system which I can “interrogate” to see exactly what the default password settings are. I can then (safely) experiment with a disposable until the same “interrogation” gives the same results. Repeat for Dom0 and that should give me confidence that at least the root password is back to what it was.
I do not pretend to understand everything these do, and can take no responsibility for anybody that tries them, but I seem to have successfully reverted back after inadvertently setting a root password.
To revert back, I entered …
sudo passwd -l root
sudo usermod -p '!' root
The results from the system now returned to default are …
Which only differs in the dates from the results I got from an unchanged Qubes installation.
So that problem is solved and without locking myself out.
Now to have a go at my hard disk and backup problems
