I will use this:
I create /etc/qubes/backup/myprofile.conf
include:
- work
destination_vm: sys-usb
destination_path: /media/my-backup-disk
passphrase_text: "My$Very!@Strong23Passphrase"
How can i use a sata disk instead of a usb disk?
I will use this:
include:
- work
Either attach the disk to a back up qube, and use that as destination_vm
and specify destination_path to point to the mounted disk, or set up a
new pool on the disk, create a new qube in the pool, and back up to
that.
I said under your other question that I’d talk about backups over here…but it looks like unman has covered it pretty well.
If it’s mounted in dom0, use destination_vm: dom0
i thought dom0 was not possible. thanks for your advice.
and what do i have to enter for destination_path?
The mountpoint (+ maybe a directory somewhere on it).
E.g. if the disk is mounted at /mnt/disk2/ you could create a directory backups/important/ on its filesystem and use destination_path: /mnt/disk2/backups/important
BTW you can also use the qvm-backup --profile=myprofile command instead of the raw admin API.
but i also have to configure qvm-backup!?
or what’s the advantage?
The admin API is more like a low level interface for programming where you have to fiddle with every detail yourself. If there’s an existing qvm- program that takes care of invoking the admin API for you, it’s normally easier to use that.
But yes, you still have to create a profile (or use the equivalent qvm-backup command-line options without an existing profile, although that’s more complicated for the passphrase).
