How can I see what features are available with the qvm-features command. I was wondering if there is a way to show a list, or where I can see such information, my standalone qubes for some reason are missing quite a few things, I want to add the copy and paste clipboard for example. In any case, if it is not with the command I already said, does anyone know which one it is? Or I need to install specific packages inside the cube, I’m using an iso downloaded.
man qvm-features
Is your standalone based on a template or installed from ISO?
You need to have Qubes OS tools installed in the VM to have integration with Qubes OS.
My standalone is installed from iso.
How can install Qubes OS tools in the VM?
So there’s no way to move files from one standalone to another?
You need to have Qubes OS tools installed in the system to have support of copying/moving files like this:
But you can move files from one standalone to another some other way:
- using network
- using USB disk
- using block device
- mounting both standalones disks in some other qube and moving the files between them in this qube
