I want to enable virtual Performance Monitoring Unit (vPMU) for a single VM so I can use perf. I’m aware of XSA-163. The VM will be an isolated AppVM without network access and only AppVM with vPMU.
I tried editing the libvirt XML template for the HVM or PV VM by modifying: /etc/templates/libvirt/xen/by-name/<vm>.xml
I need to profile something using intel vTune from time to time, but without vpmu that doesn’t work too well (all the interesting pieces require that). I’m trying to figure out if using appVM is possible, or if I need to e.g. buy a separate hardware for that.
