High Speed Network Cards with QubesOS 10Gbps+ | Question
Is anyone here using QubesOS with high speed network cards? I am thinking of 10Gbps -25Gbps speeds. Is this even possible with QubesOS or does the network stack of the VMs reduce the throughput severely (sys-net > sys-firewall > backupVM)?
I want to backup my QubesOS system over the network very fast. My storage server can handle 25Gbps, so I am considering adding a 25Gbps card to my QubesOS system.
Any thoughts on this? Will it work?
It should work, but you’ll need to have CPU with enough cores and assign more VCPUs to the sys-net/sys-firewall/etc qubes to handle the high bandwidth.
As Apparatus mentions, it should work. Also read the last post from this 2018 thread:
Is the virtual NIC not only 1gbps?
No, for example, the iperf3 speed test between two qubes attached to the same sys-firewall that has 2 VCPUs will show me 3.5 Gbits/s speed with the CPU usage in sys-firewall being the bottleneck.
Sorry for being afk for so long. Thanks for all the great answers! I really appreciate it. Mellanox cards would also be my preferred way to add networking.
I agree with you that CPU will most likely be the limiting factor. Is QubesOS networking mostly single-threaded or does it make sense to add more VCPUs? Is it wise to go for more high clocked cores or scale horizontally?
