It worked for me, Thanks to everyone for the help
i did made a TemplateVM when i will restart it will dissapear so i will try to make everything back ahah
After is it normal if my template just crashed and dont want to open firefox or the terminal ?
Please DONT do this.
The whole point in the move from apt-key is that repositories should be
validated by individual keys. Putting the key in to /etc/apt/trusted.gpg.d
undermines this.
It runs counter to the Debian way. AND it runs against Kali advice
itself. Look at this blog entry from earlier in the year-
You’ll see that the Kali advice is that the signing key should be placed
in /usr/share/keyrings.
Do the right thing: put the key in /usr/share/keyrings, and reference
it in the repo definition using signed-by .
I understand why it is against Kali advice because my template dont even want to start again ahah, but thanks when i will have the time i will try to do what u sent
I had issues using Kali on QuBes too.
I installed Kali using ISO without the qubes integration (packages).
in the end, I followed these steps;
so far it seems to work fine
script example to manage qubes packages hold/unhold;
as per suggest in the forum keep qubes packages with ‘hold’
#!/bin/bash
if [ "$#" -ne 1 ]; then
echo "Usage: $0 {hold|unhold}"
exit 1
fi
action=$1
# Get all qubes- and qvm- packages
packages=$(dpkg --get-selections | grep -E 'qubes-|qvm-' | awk '{print $1}')
# Perform the specified action
for pkg in $packages; do
if [ "$action" == "hold" ]; then
sudo apt-mark hold "$pkg" && echo "Package $pkg has been put on hold."
elif [ "$action" == "unhold" ]; then
sudo apt-mark unhold "$pkg" && echo "Package $pkg has had its hold removed."
else
echo "Error: Invalid action: $action. Use 'hold' or 'unhold'."
exit 1
fi
done
echo "Action '$action' completed for all qubes- and qvm- packages."
Thanks i will try it when i will get the time
