Help recreating an issue
Hello QubesOS community! I would like to lend some help so I can recreate a computer-killing issue that happened to me. I don’t have any spare computers with enough power to run QubesOS, and I’m not doing it on my computer so I don’t have to reinstall stuff a million times.
Steps to recreate
  1. Turn on QubesOS on a computer with an NVIDIA GPU
  2. Create a standalone Debian 13 HVM with kernel=‘’
  3. Setup Debian 13
  4. Attach the NVIDIA GPU and its audio module
  5. Attach regular audio thing (ich6)
  6. Turn on qube, install NVIDIA drivers preferably and do something for a bit, just to solidify our use
  7. Shutdown QubesOS
What happened to me after turning my system back on
I got a message about my computer powering off. I was not able to identify a direct cause from the logs but I assume its the conflicting audio modules. I ended up using Qubes Recovery shell to get a .img file from each qube (yes I have been doing backups, but I hadn’t done it as often as I do now).
What should happen
I turn on my computer just fine, and I get a warning message like “Conflicting audio modules in qube debian-13-gpu”.
Additional Information
I use an Asus TUF Gaming A17 FA707NV, which has a 4060 GPU, and occurred while running QubesOS R4.3.1
Did you add qubes.hide_pci=... to your GRUB cmdline? Like here: https://neowutran.ovh/qubes/articles/gaming_linux_hvm.html
No, that’s a good idea. I can’t try it though. I did try qubes.skip_autostart and nomodeset and maybe another I can’t think of right now
