I followed these instructions to create a Kali template.
However, I am not sure which VM terminal to run the commands in. There’s a mix of $ and # and it doesn’t specify which VM to run the commands in.
If anyone has created a Kali template, could you please explain a little more?
If you’re installing Kali, you should know what these mean. Anyway, $ for commands ran as user, # for commands that require elevated privileges.
This was pretty much self-explanatory since dom0 is based on Fedora, and Kali is based on Debian.
Run qubes-dom0-update and commands starting with “qvm-” in dom0 (except for the qvm-copy that you have to run in a DisposableVM as mentioned in the guide). All the others in the Kali vm.
