HDMI display no input from intel graphics
Hdmi external monitor is not recognized (No video input). I am running a fresh install of release 4.1.2 on a Novacustom NV41 (certified HW) and also tried to run dom update.
00:02.0 VGA compatible controller: Intel Corporation Device 46a6 (rev 0c) (prog-if 00 [VGA controller])
        DeviceName: VGA compatible controller
        Subsystem: CLEVO/KAPOK Computer Device 4041
        Flags: bus master, fast devsel, latency 0, IRQ 255
        Memory at 81000000 (64-bit, non-prefetchable) [size=16M]
        Memory at 90000000 (64-bit, prefetchable) [size=256M]
        I/O ports at 1000 [size=64]
        Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
        Capabilities: [40] Vendor Specific Information: Len=0c <?>
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [ac] MSI: Enable- Count=1/1 Maskable+ 64bit-
        Capabilities: [d0] Power Management version 2
        Capabilities: [100] Process Address Space ID (PASID)
        Capabilities: [200] Address Translation Service (ATS)
        Capabilities: [300] Page Request Interface (PRI)
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
   1920x1080     77.00*
If you opted to buy the one with NVIDIA, that is expected.
If not, i’d try to create xrandr profile via cvt 1920 1080 60 for the diagnosis start.
solved:
The hdmi screen got recognized during a restart with the screen attached after the dom update. There is a minor glitch while prompting for the enryption password, but other than that it works.
Great!. It would be a good idea to mark your post as an answer so it could help other users too.
