Purism Librem Mini v1
Remarks
Things I’ve tested:
  • WiFi
  • Ethernet
  • Sound
  • USB
Not tested:
  • microphone
  • bluetooth
Using the Librem Mini connected to a KVM switch, and i was able to setup a sys-usb VM which is working fine.
Temperatures are about 60°C, mostly below 60°C, if there is something CPU intens work between 60-70°C.
Qubes-HCL-Purism-Librem_Mini-20210505-233313.yml (892 Bytes)
Thank you @onequbesuser for your HCL report. It is now part of this pull
request:
… and will be visible on the website soon!
