This error that you saw in the Initial Setup:
Exception: Qubes initial configuration failed. Login to the system and check /var/log/salt/minion for details. You can retry configuration by calling ‘sudo qubesctl --all state.highstate’ in dom0 (you will get detailed state there).
Was related to these errors:
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: ----------
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: ID: qvm-appmenus --get-default-whitelist debian-12-xfce | grep -i 'firefox\|term' | qvm-appmenus --set-whitelist=- --update default-dvm
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Function: cmd.run
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Result: False
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Comment: Command "qvm-appmenus --get-default-whitelist debian-12-xfce | grep -i 'firefox\|term' | qvm-appmenus --set-whitelist=- --update default-dvm" run
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Started: 00:21:04.355834
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Duration: 464.03 ms
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Changes:
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: pid:
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: 11238
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: retcode:
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: 2
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: stderr:
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: usage: qvm-appmenus [--verbose] [--quiet] [--force-root] [--help] [--init]
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: [--create] [--remove] [--update] [--get-available]
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: [--get-whitelist]
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: [--set-whitelist PATH | --set-default-whitelist PATH]
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: [--get-default-whitelist] [--source SOURCE] [--force]
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: [--i-understand-format-is-unstable] [--file-field FIELDS]
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: [--template TEMPLATE] [--all]
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: [VMNAME ...]
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: qvm-appmenus: error: refusing to run as root; add --force-root to override
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: stdout:
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: ID: qvm-appmenus --update whonix-workstation-17-dvm
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Comment: Command "qvm-appmenus --update whonix-workstation-17-dvm" run
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Started: 00:21:12.986649
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: Duration: 410.16 ms
Sep 26 00:21:32 dom0 org.fedoraproject.Anaconda.Addons.QubesInitialSetup[3343]: 12919
It failed to update the appmenus for you disposable templates using qvm-appmenus --update command.
It failed because it couldn’t start these disposable templates, because sys-net failed to start.
You can try to manually run the failed commands in dom0 terminal to fix it after you fix your sys-net problem:
These are the actual errors that prevent from using Qubes OS, but they are not caused by the error during Initial Setup.
You can fix it like this:
PCI troubleshooting — Qubes OS Documentation
