Hewlett-Packard Elitebook 820 G1
Remarks
Suspend works. Webcam and Microphone works. TPM untested.
With fedora-32-xfce-minimal, had to install " iwl7260-firmware " in the templateVM used by sys-net to get internal wifi working.
Qubes-HCL-Hewlett_Packard-HP_EliteBook_820_G1-20201013-083237.yml (881 Bytes)
@dispuser5132
Thank you for reporting :slight_smile:
However If I’m not wrong after executing command that generates HCL report, there is little user correction needed where FIXME or multiple choices present. Also some other fields like Remark, Author and Link.
