HCL - Dell Optiplex 9020: R4.2.0
This is my studio processor I use with a ps/2 keybord, usb mouse, 2TB SATA SSDD, 24GB RAM & dual Samsung LS27LC39 27" curved monitors. I opted for a debian-12 system configuration over the fedora-38 system I used with R4.1.2
The upgrade was a glitchless breeze.
[Qubes-HCL-Dell_Inc_-OptiPlex_9020-20240303-
layout:
  'hcl'
type:
  'Space-saving'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Dell Inc.
model: |
  OptiPlex 9020
bios: |
  A25
cpu: |
  Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation 4th Gen Core Processor DRAM Controller [8086:0c00] (rev 06)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller [8086:0412] (rev 06) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Ethernet Connection I217-LM [8086:153a] (rev 04)
memory: |
  24484
scsi: |
  DVD+-RW GTA0N    Rev: A1C0
  WDC WD20EZAZ-00L Rev: 0A80
usb: |
  3
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.0
    xen: |
      4.17.2
    kernel: |
      6.1.62-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
Qubes-HCL-Dell_Inc_-OptiPlex_9020-20240303-155712.yml (932 Bytes)
Thanks for the HCL report. I just submitted a pull request to add it to the HCL database.
Best,
Flavio
Thanks for the heads-up Flavio, on both my Dell Optiplex 9020 and HP-Envy-17m HCLs. I’m retired, my rice-bows having been music and engineering technology. As an erstwhile hacker and median power-user, I’m now engaged in literary pursuits. So the less time I spend under the hood, the more time I have for my various projects. Qubes is the best thing since the vi editor, as far as I’m concerned.
Regards,
<djr>
Del Riker
That’s great feedback and the type of retirement that I will love to have :slight_smile:
Enjoy life!
