HCL - Chuwi Minibook X n150
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  CHUWI Innovation And Technology(ShenZhen)co.,Ltd
model: |
  MiniBook X
bios: |
  DNN20A V2.51
cpu: |
  Intel(R) N150
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Alder Lake-N Processor Host Bridge/DRAM Registers [8086:461c]
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Alder Lake-N [Intel Graphics] [8086:46d4] (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Alder Lake-N PCH CNVi WiFi [8086:54f0]
memory: |
  16126
scsi: |
usb: |
  1
certified:
  'no'
versions:
  - works:
      'yes'
    qubes: |
      R4.3.0
    xen: |
      4.19.4
    kernel: |
      6.18.19-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
Working
  • Wifi
  • Video out with a usb-c dock
  • Sound
  • Camera
  • Microphone
  • Suspend - S3
  • Touchscreen
Not tested
  • Bluetooth (detected, should work)
Notes
As the screen in a portrait one, it needs to be rotated manually. In addition, the touchscreen input needs to be rotated with the below command, as it does not rotate when using Display settings.
xinput set-prop "pointer: Goodix Capacitive TouchScreen" --type=float "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
HCL-Chuwi-Minibook-X-N150.yml (817 Bytes)
