Remarks
Installation error: Qubes OS was installed twice via normal method. The first time it was using a beta version with Spanish settings and with all three OS templates. The second time was with just the Fedora 37 template and both times the following error message came up after confirming the initial setup of the OS:
Qube startup error: Attempting to start any qube aside from dom0 would give the error message below:
Suspend error: The system is able to wake up and log back in after suspend but the touchpad won’t be responsive.
layout:
'hcl'
type:
'Convertible'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
ASUSTeK COMPUTER INC.
model: |
ZenBook Q406DA
bios: |
Q406DA.312
cpu: |
AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
cpu-short: |
FIXME
chipset: |
Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex [1022:15d0]
chipset-short: |
FIXME
gpu: |
Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] [1002:15d8] (rev c2) (prog-if 00 [VGA controller])
Advanced Micro Devices, Inc. [AMD] Sensor Fusion Hub [1022:15e4]
gpu-short: |
FIXME
network: |
Intel Corporation Wireless 8265 / 8275 [8086:24fd] (rev 78)
memory: |
6091
scsi: |
SanDisk SD9SN8W2 Rev: 6002
USB DISK 2.0 Rev: PMAP
usb: |
2
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.2.4
xen: |
4.17.5
kernel: |
6.6.77-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Qubes-HCL-ASUSTeK_COMPUTER_INC_-ZenBook_Q406DA-20231127-181916.yml (1.0 KB)
Qubes-HCL-ASUSTeK_COMPUTER_INC_-ZenBook_Q406DA-20231127-181751.cpio.gz (8.8 KB)
