After fresh installing Qubes 4.1.0 the hard drive i had early been using with 4.0.4 became read only. The drive is a second drive (a block device) i use to back up files not the one Qubes is loaded on. Is this an intended feature? is there a solution? (i did attempt changing permissions using CHOWN but it dint work).
I can remove it and backup the data then reformat if need be so its not an urgent issue.
