Disclaimer: this is my first attempt to write a guide.
I tried to configure ProtonVPN in Qubes 4.3 with basic OpenVPN and
it was in fact very simple and seems to work fine.
I’d be very grateful if anybody has security improvements or other suggestions.
Guide to setup ProtonVPN ProxyVM for Qubes OS R4.3.0-rc2
In this guide I will detail how to configure a ProxyVM to tunnel all connections through Proton VPN.
This is based on OpenVPN and not on tools from ProtonVPN.
This is based on the official “Linux/OpenVPN” instructions from Proton.
See: How to manually configure OpenVPN for Proton VPN in Linux | Proton VPN
Step 1 - Create the VM
Create a standalone VM using the Debian13-xfce template.
Use the default as NetVM.
Remember to click Provides Network.
After creation, go to Qube Manager, <ProtonVPN>, Settings-> Services and add Network Manager.
Step 2 - Install OpenVPN
Open the ProtonVPN terminal.
sudo apt install openvpn
sudo systemctl disable openvpn.service
Reboot ProtonVPN.
Step 3 - DNS Related Configuration
sudo apt install openresolv
sudo apt install wget
sudo wget "https://raw.githubusercontent.com/ProtonVPN/scripts/master/update-resolv-conf.sh" -O "/etc/openvpn/update-resolv-conf"
sudo chmod +x "/etc/openvpn/update-resolv-conf"
Step 4 - Download ProtonVPN OpenVPN configuration files
Go to your ProtonVPN account and find your credentials (username/password).
NOTE: These are specific for OpenVPN and they are not your usual username/password for accessing all Proton services.
In ProtonVPN create a file with two lines, one for the username the other for the password.
cd /rw/config/
sudo mkdir vpn
cd vpn
sudo nano ProtonCredentials
# write username on the first line
# write password on the second line
From ProtonVPN download your desired server configuration file. For example the “Switzerland UDF” file is called `sudo apt install
From ProtonVPN download your desired server configuration file. For example the “Switzerland UDP” file is called `sudo apt install
From ProtonVPN download your desired server configuration file. For example the “Switzerland UDP” file is called ch.protonvpn.udp.ovpn.
Note: You might want to choose a TCP configuration file, depending on your needs.
Place this file in /rw/config/vpn/
Now edit this file to include the reference to the credentials:
sudo nano /rw/config/vpn/protonvpn.udp.ovpn
# Find the line "auth-user-pass"
# Edit to:
auth-user-pass /rw/config/vpn/ProtonCredentials
Start the VPN service
Start the service with:
openvpn --cd /rw/config/vpn/ --config ch.protonvpn.udp.ovpn --daemon
Now go to Qube Manager and set as ProtonVPN as NetVM of some appVM.
Open Firefox in appVM and visit https://www.dnsleaktest.com/ to check that everything works as expected.
If it does, add the following line to /rw/config/rc.local to automatically start the VPN when ProtonVPN VM starts:
sudo /rw/config/rc.local
# Add
# openvpn --cd /rw/config/vpn/ --config ch.protonvpn.udp.ovpn --daemon
