Hello Everyone!
I want to install GpgFrontEnd Could you please guide me how to install and run it through appVM
There are two ways.
Flathub:
GpgFrontend is available on Flathub. The main advantage of installing via Flathub is automatic software updates and automatic creation of an Application menu entry, if you follow @solene’s following guide:
After completing the above configuration, install GpgFrontend with this command in your template terminal:
flatpak install flathub com.bktus.gpgfrontend
AppImage:
GpgFrontend also provides an AppImage.
Download it, make it executable, and run it. Done.
Thank you very much
