Dear all,
I am new to Qubes and after trying to run it on my current system for experimental reasons I decided to buy a dedicated desktop Qubes.
For security reasons I wanted a computer that supports PS2 and VGA and it was quite a hassle to find a solution. I couldn’t find any modern pre build systems so I decided to go the DIY route.
Surprisingly enough the only Motherboard I could find supporting this is actually a very modern 12 Gen board: GIGABYTE H610M S2H. Since it is 12 Gen I would like to pair it with the 12700K because on the HCL it seems to be working quite well with Qubes.
My question is: Does anyone know if the Ethernet and Audio on the board would work with Qubes ?
Thank you in advance.
