hello
i need your help
I can suggest something to try… I’d first try cloning the pi-hole vm and inserting the clone between sys-vpn and ChocolateVM. In the cloned pi-hole vm be sure to set the dns IPs to dns servers that are used by your vpn.
how to set dns ip addresses on dns servers used by my vpn,
- I use protonvpn, I want to know the dns of the dns server used by my protonvpn
- how to set dns ip addresses on dns servers used by my vpn,
the list of my machines
piholeVM
piholeVM-clone
chocolateVM
sys-firewall
sys-vpn
thank you
sys-net
bananaVM
