Finish configuration button disappears
After clicking the button in the middle and configuring my install, going back to the initial page, finish configuration inst visible
Do you mean you don’t see the the “FINISH CONFIGURATION” button here at all?
Or you see it but it’s grayed out?
Do you see the QUIT button?
I don’t see finish configuration or quit at all, or the please complete items etc
It’s visible when I first boot up , bit when I click in the center , then configure things and go back, it’s gone
Maybe the buttons are just off screen and you can try to press Tab and Enter to press on the button.
Try to press Tab once → press Enter.
Try to press Tab twice → press Enter.
Try to press Tab trice → press Enter.
Check what will happen when you press on Enter.
You can also press Tab / Shift+Tab to see where the selection is going.
Tab and enter and arrow keying around worked
Thank you!
